tonyone01
Recently purchased my new ( to me) boat and the engines need to be serviced. They are Cat 3216. Does anyone have any recommendations for an engineer in the Cardiff area ?
Tony
Tony
Tony, a quick thought. There are about 12 engine anodes in the 3126, so can be pricey. There is a supplier in the USA called www.boatzinc.com. These are substantially cheaper than UK sources. Not. Sure about shipping costs, as I had them sent to my US office, and brought them back from there. If you get stuck, one of my colleagues could bring them over. You will also need 25l SAE30 oil per engine (not multi grade). Default is Shell Rimula R3 +30. I am going to try for an alternative, but may go back to the Shell.
Finnings Tech Support are really helpful over the phone.
How many hours have your engines done?
Tony, I got the Exol oil locally from Studley, Clarke Oils. The Marine 123 was £44+vat for 25 litres. Do you still need the anodes?As Rafiki says, good info Sunquest. I have however already ordered the oil, not exactly a good deal as I have had to order 3 x 20ltr drums :-(
Sunquest I guess we have the same boat ? Sunquest / Sealord / Admiral. Do you by any chance have a copy of the owners manual ?
Ok, we will keep a lookout for you. We are on H3 at Portishead. Not sure if we are heading your way on the Friday or Saturday. This will depend on the tides and weather.Hi Paul we are also planning cruise at Easter - to Portishead ! We are setting off about 07:00 from Penarth to arrive at Portishead around HW. I'm guessing the closest we will get to catching up is as we pass each other maybe we can swop berths for the weekend ? I will make sure there is plenty of electric in the meter.
Quick update. Alan came down yesterday to change the impellers, but we found the port engine water pump was leaking. That is off now and being repaired, so it looks like we will be moored up at Portishead for Easter. Shame, as we were really looking forward to the trip. However I did not want to do this with a known fault. So we might see you here.
I will be over this evening in readiness for the PCC trip to Gloucester. I may see you.
We saw Fortuna and Athena on our trip to Bristol last week, I'm not sure if they are on here.
Allan
