Carpeting advice
ParaHandy
18 Nov 2001
Re: a farmer writes ...
if your pontoon is like others then we have similar problems getting our animals across the many cattle grids wherein their heels get caught in the gaps. the solution is simple: lay small strips of 4x2 (adjust as required) in the gaps. this is a low maintenance, long lasting solution ...
hope that helps
paulrossall
22 Oct 2001
What you need is some lateral thinking
The obvious solution to this problem is to park the boat next to the car in the car park. This would eliminate any pontoon walking. If you are concerned that all the liveaboard men would not be able to admire your morning walk then you should park the boat at the other end of the car park from the car.
The alternative is to become a "home worker" and then you could get all dressed up in your office gear, put your shoes on, and then sit down at the saloon table (assuming you have one) and work away!
What do you recon??
jon_bailey
3 Feb 2002
Teignmouth, Devon
www.cerberusstorage.co.uk
What about Astroturf (or equivalent). Would then be like walking through a fresh field of grass every morning. Could even put in a few pot plants and the odd cow to make it really feel like the country - but then you'd need your wellies (boating boots) again.
jimi
19 Dec 2001
St Neots
Stop calling Pauline an old cow! What she really needs to do is to cover it in linoleum so she can scrub it...
<hr width=100% size=1>.. its life but not as we know it ..
lanason
23 Jul 2001
Malvern, Worcs
Re: What you need is some lateral thinking
or even better park the car on the pontoon next to the boat - that little SMARTY thingy is small enuf to drive down the pontoon.
Actually its probably easier to carry the car to the boat /forums/images/icons/blush.gif /forums/images/icons/wink.gif
<hr width=100% size=1>Adrian - <A target="_blank" HREF=http://www.arweb.co.uk/argallery/kelisha>More Pics of Kelisha</A> /forums/images/icons/smile.gif
sailbadthesinner
3 May 2002
Midlands
Re: i think you will find
Pauline is in brighton
some sort of hardwood finish is de rigeur
at least i remember hearing that most gentlemen in brighton who have visitors when stern-to have their entrances waxed
<hr width=100% size=1><font color=red>if guinness is good for you. i must be very very good</font color=red>
