russ
What is recommended as a safe and effective way of cleaning and preventing mildew growth inside my boats canopies ceiling?
I can recommend Patio Magic ?
As above . Patio Magic diluted 1+4, or even 1+9, Spray or brush on and allow to dry.What is recommended as a safe and effective way of cleaning and preventing mildew growth inside my boats canopies ceiling?
I use Patio Magic or the products from Lidl/Aldi (diluted 8:1) annually above deck generally, to good effect., and this year will be wiping over the internal deckhead moulding and the uholstery on liftout as some mould appeared during lockdown.As above . Patio Magic diluted 1+4, or even 1+9, Spray or brush on and allow to dry.
Keep an eye open for Doff Path, Patio and Decking Cleaner from Aldi. Same stuff, same concentration but less beer tokens.
Also use (1+9) anywhere that mildew tends to form around house and boat.
Good also for killing algae on ropes.etc.
Avoid chlorine based mould killers.
The patio magic type product sprayed on while it was on the boat was not effective on the inside of the canopy for me.
I took the canopy home so it could be laid out on the lawn and cleaned/scrubbed with plenty of detergent / water. Several passes were required as the wet canvas looked clean but dried still with mildew spots in some areas .
I may have used some other product of a similar nature. Buy yes the impact on mildew fungus was nil. But it does kill green algae.Patio Magic is often recommended; this only contains benzalkonium chloride.
Slight resurrection. I've got some quite extensive mildew on my two year old canopy canvases. I've got Boracol available as I'm planning to treat the teak decks again this autumn; if I want to use this on the canvas, any specific tips or suggestions? Eg dilution level, application method. etc. Be pleased to hear any experiences.Hallberg Rassy recommend a product called Boracol, which is generally sold as a timber preservative. It’s highly effective in killing green algae, mould/mildew spores and termites. The two active ingredients are disodium octaborate (a fungicide) and benzalkonium chloride (an algaecide). It’s a colourless liquid. I used it on my old HR352's deck and sprayhood, and was pleased with the results....
Do you clean the sprayhood as best you can beforehand?
