I have started cleaning the vinyl windows, but its going to take awhile with the state they are in from the previous owner.
I have tin of Brasso and T-Cut which both are hard work. Did try a plastic scouring pad the type with sponge on the back, bad results marking the vinyl.
So as seen on the Tube, some use a 75mm polishing pad in a drill on their soft jeeps etc., as anything faster than drill speed (ie: disc grinder) could burn the vinyl.
Which do you think would be more suitable Rayon or Wool pads.
Also as many say, Pledge does soften old vinyl from its brittle state.
