Kylora
I know that you can damage an alternator by running it with no connection to to the output, but can you do the same to a dynamo (which is self excited)
I have a Volvo MD6A, with an alternator supplying the domestic battery, and a dynastart connected to the engine battery.
I noticed that the dynastart warning light was on, and on investigation found that the (charging) output cable had broken off the terminal.
I've replaced the cable, but no output, only 0.5 volt. The unit still works OK as a starter.
I have a vague memory from my time on a ship with DC mains, that the cure for a Genny which wouldn't self excite, was to give the casing a mighty hit with a big hammer!
Is it likely that the shunt coils have burnt out? The dynamo would have been pruducing volts which would have been supplied internally to the shunt coils, but the regulator would not have been receiving volts from the output cable, and so wouldn't regulate. I don't know how high the volts might have risen, certainly the engine wasn't running very fast.
Any thoughts would be appreciated.
Ash
Ash
