dpb
The engine is an AQAD41.
The pipe is the lower one coming of the exhaust elbow in the general view that I assume carries the raw water to the base of the exhaust pipe where it connects onto the transom shield.
As per the close up picture......which shows the leak.
Whilst it only leaks with the engine running, I am thinking that the pipe must be full of water at rest as it is below the water line.......there for making any attempt at repair risky with the boat in the water........assuming I work out how to get to the fitting in the first place as it is at the bottom of the rear of the engine.
Can anyone confirm this?
The way I see it is that at the moment I have a boat I can use subject to living with the leak (about a gallon per hour when engine running), against it turning into a real pain of a job if I try it now rather than leave it till next lift out.....expecially if the bolt heads snap off when I try turning them!!!!!
Any thoughts??
Any thoughts??
