MissFitz
The rudder on my Sonata has never been antifouled as the previous owner took if off between races. I’m finding this a bit of a pain so would like to antifoul it. At the moment it is varnished. Can I just put antifoul (hard) on top or will it need to be prepped/stripped? Also, some of the varnish has worn off the leading edge of the rudder above & below the waterline. If I dry it out can I just revarnish the bits where the wood is showing through or will that not work? If so, what else do I need to do before antifouling?
