Otter
Hydraulic steering issue - we have full hydraulic steering, with a simple wheel acting as pump in the wheelhouse. The boat sat unused for two years and I foolishly never checked the steering fluid level. Today after another 2 months non use and with her due to go back in, I checked the steering and there was no fluid in the steering pump. I checked the lines and can't find a leak, then I noticed that the nut on the wheel pump used for filling had a designed hole, about the width of a big sewing needle. Can ATF evaporate through that? I bought a bottle and put in about 200ml; assuming the level hadn't been topped up for about 4 years, is that feasible as a cause or do I have to look elsewhere for the problem? the wheel is the highest point in the system so I'm assuming the air bubbels will rise to that point? The wheel is now a bit 'juddery' and I'm guessing that's due to air in the system that has to come out???
Thanks for advice.
Thanks for advice.
