BabaYaga
In a thread the other day
http://www.ybw.com/forums/showthread.php?514825-new-12v-installation&p=6687481#post6687481
I made a comment on what seems to be a fairly wide spread view on battery charging, namely that charging current must not be too high in relation to the total Ah capacity of the battery or battery bank being charged.
This view is supported by the recommendation that Trojan batteries make in their Users guide
https://www.trojanbattery.com/pdf/TrojanBattery_UsersGuide.pdf
where they say (p. 17, 18, 19) that charging current must be limited to 13 percent of Ah capacity for wet cells and gels and 20 percent for AGMs. (Capacity in Ah here defined as C20, which is most common).
I think this recommendation is very conservative and a bit surprising, even if I have read similar recommendations before.
The mainstream view, as I understand it, is that a battery will self regulate the current and only accept what it can 'swallow' – as long as the charging voltage is controlled (not allowed to rise above e.g. 14.4V or similar set point).
This perception goes well with the fact that alternators in common boat installations are likely to put out a current that by far exceeds 13 percent of Ah of the battery bank it charges.
In addition, makers of battery chargers also seem to have a much more relaxed attitude on the relation between maximum charging current and battery capacity. Victron says up to 25 percent of total Ah, Mastervolt says up to 50 percent and CTEK allows even higher.
So who is right here? Are Trojan batteries extra sensitive? (I always thought of them as capable of taking a lot of abuse...)
Opinions, views?
Opinions, views?
