5 Jul 2013 #1 nigelmercier RIP Joined 20 Jun 2007 Messages 16,234 Location Live in Kent, boat in Canary Islands www.bavariayacht.info Has anyone found a blowlamp that can be connected to a Campingaz 907 cylinder?
5 Jul 2013 #2 sarabande Well-Known Member Joined 6 May 2005 Messages 36,182 Visit site I think you will need a regulator that allows more puff to the torch than to the standard cooker. That's certainly the case for my propane set up. A normal Camping Gaz uses a 28mb regulator; my weedkilling torch uses a 0 to 1 bar regulator. Perhaps one of these ? http://www.calor.co.uk/shop/product/re912-002-high-pressure-butane-regulator/388/ Last edited: 5 Jul 2013
5 Jul 2013 #3 Searush Well-Known Member Joined 14 Oct 2006 Messages 26,779 Location - up to my neck in it. back2bikes.org.uk It would be a bit heavy compared to the alloy canister ones! You can get tap connectors that work at cylinder pressure, but I don't know how you would connect a high pressure hose to the blowlamp fitting.
5 Jul 2013 #4 DaveRo Well-Known Member Joined 15 Nov 2007 Messages 3,026 Visit site I have one, made by camping gaz, but I bought it 30 years ago. I still use it for soldering copper water pipe joints. No regulator.
5 Jul 2013 #5 Leighb Well-Known Member Joined 8 Aug 2007 Messages 7,089 Location Suffolk Visit site I have one, not sure of make, had it many years. It connects via a flexible hose to the Camping Gaz cylinder.
5 Jul 2013 #6 Stork_III Well-Known Member Joined 6 Aug 2002 Messages 18,748 Location Here and There Visit site Thisone? http://www.campingaz.com/co.za/p-23233-garden-torch-907.aspx
5 Jul 2013 #7 alahol2 Well-Known Member Joined 22 Apr 2004 Messages 6,144 Location Portchester, Solent www.troppo.co.uk More likely this one... http://www.campingaz.com/co.za/p-23814-chalugaz174-profil.aspx
5 Jul 2013 #8 R richardsnowstar Well-Known Member Joined 21 Jun 2010 Messages 241 Location Horley/Tignes/Portsmouth Harbour www.snowstar.co.uk Or this one? http://www.campingaz.com/co.za/p-22840-kit-chalutorch-profil.aspx
6 Jul 2013 #9 nigelmercier RIP Joined 20 Jun 2007 Messages 16,234 Location Live in Kent, boat in Canary Islands www.bavariayacht.info Yes, plenty in South Africa, but none in the UK. All I really need is a small unit for occasional use with stubborn nuts etc. I guess I'll get a standalone unit.
8 Jul 2013 #10 alahol2 Well-Known Member Joined 22 Apr 2004 Messages 6,144 Location Portchester, Solent www.troppo.co.uk Any of these any good then... http://www.gasproducts.co.uk/acatalog/Bullfinch_Gas_Blow_Torches___Burners.html Perhaps a bit expensive for occasional use.
