lynallbel
Apologies first, as just joined and cannot see a new members/say help section?
Issue is calorfier will not get hot when under power, system works just fine using the immersion element.
Today I ran the Port engine for 20 minutes at fast idle 1000rpm, pipe to calorfier got hot but only for approx 8 feet down the pipe, which is 4 feet short of the tank, the heat did not reach the calorfier, I then upped the revs to 1500rpm for 10 minutes and hot water actually got there, but still no hot out of the tap, not even tepid.
The port engine has always run cooler than the starboard Im assuming due to the calorfier acting as an additional heat sink? but after a few hours running the engine temperature does come up, but still not as hot as the starboard engine which runs at approx 180degf, Port engine seems to hang around the 150degf mark
The whole system is fed by a single impellor pump pressurising the cold water supply which also feeds the hot water tank.
It has been fine for the last couple of months, then last weekend just packed up.
The engine had been running at approx 1500rpm for 3 hours, which on previous trips gave lots of lovely hot water.
I am thinking engine thermostat or water pump impellor?
Thanks for any replies
