Calling the coatguard by DSC?
panther
16 Aug 2004
Portishead, Bristoll Channel
www.prestige36.co.uk
I just had a go at entering the MMSI for Swansea CG on my new Raymarine 240E
It won't seem to let me enter it as it starts 00 - full list of CG MMSI's here
<A target="_blank" HREF=http://www.coastalradio.greater-peterborough.com/mmsi.htm>http://www.coastalradio.greater-peterborough.com/mmsi.htm</A>
Now on RIB-Panther I had a nice ICOM, amd all the CG stations were pre-programed - I also remeber that when calling a CG by DSC you did not have to set the working channel as this is set by the CG.
How many people (comercial or leisure) call CG by DSC? (not many Raymarine users I suspect!)
Is there a DSC spec that has specific bits about MMSI's starting 00? - Like they can not be user programed - or don't have to set the working channel?
Cheers
Jools
ps - I've also asked Raymarine support - I'll post what they say
__________________
www.ribpanther.co.uk
<hr width=100% size=1>www.ribpanther.co.uk
Didn't know the coastguard stations started with 00, Julie where are you! She would know.
No Sorry, i dont call swansea on DSC, we only use it between our own vessels - but then again swansea CG are not that *busy* so voice calls get through.
My mate has done it, he programmed the number then just did a normal call (at least that what i think he did)
<hr width=100% size=1>Thanks
Leyton
EXTAR Software - Software that works for you
Phone : 07803 139 736
Oh Colin!! All UK Coastguard stations MMSI's start with 00. I've not come acroos the probeem with other DSC sets having a problem programming a "00" prefix into the directory.
<hr width=100% size=1><A target="_blank" HREF=http://arweb.co.uk/argallery/solitaire>Some pictures</A>
On my Icom 601 it let me enter CG MMSI and it auto picks the channel to use for reply hopes this helps
As a new boy (old man) I buy of the PBO best buys due to lack of knowledge + (old & thick)
Hi
I use a Silva DSC, and don't get any problems calling Swansea CG The set aotomatically changes channel to the one set by the CG
Not that I call the coastguard very often of course Ahem!!!
Julian
Where you at in Swansea?? I'm up in phase 2.
Here's a table with the MMSI prefixes
First Digit(s) Meaning
"0" The MMSI will call a group of ships
"00" The MMSI will call a group of coast stations
"1" Reserved for INMARSAT "A" satellite terminals
"2"-"7" The MMSI will call an individual vessel
"8" Reserved for groups among neighboring nations
"9" Reserved for groups within an individual nation
So a group MMSI starts 0, CG starts 00 and normal "ships" in the UK start 2 + country code.
Thats a point is there a forum group MMSI number? - The rib.net forum has an allocated rib.net group MMSI see here
<A target="_blank" HREF=http://www.rib.net/forum/showthread.php?t=6936>http://www.rib.net/forum/showthread.php?t=6936</A>
usefull when trying to find your friends out in the solent!
The MMSI numbers which can be issued in the UK range from starting with 232 and run thru to 235.
Just to clarify this,
The first 3 digits of a ship station MMSI number are its Marine Identication Digit (MID) this identifies the vessel's country of origin. In the UK we have 4 MIDS available they are 232, 233, 234 and 235.
Mike
<hr width=100% size=1><A target="_blank" HREF=http://www.ofcom.org.uk/licensing_numbering/radiocomms/maritime_licensing/?a=87101>http://www.ofcom.org.uk/licensing_numbering/radiocomms/maritime_licensing/?a=87101</A>
Quote "So a group MMSI starts 0, CG starts 00 and normal "ships" in the UK start 2 + country code."
Already answered on ribnet but just to make sure no one misses out. The "country code" or Marine Identification Digit (MID) to give it its proper name is the first three digits ie 232, 233, 234 235 (these are the UK's MIDs) if you have any other combination it is not a UK MID.
Mike
Raymarine 240e - Check your software ver!
Great News!!!!!
My new Raymarine Radio has turned up (partly my fault for being away recently) and I installed and tested it last night. The software now seems to have been corrected and all DSC functions now are working
I Can now
1) Store the CG MMSI's in the "Phonebook"
2) make a ship to shore call (ie to the CG) via the phonebook or direct MMSI entery
3) Select a vessel from to the Phonebook and select "Position request"
I made a DSC call to Swansea CG last night - and it all worked well!!
To check your radio to see if you have old software Select Menu - System Information - Software
Old Version = v1.15, 12 Aug 2004
Can't make DSC Calls to shore stations, Can't store CG stations in phonebook
New Version = v1.17, 15 Feb 2005
All DSC functions now seem to function
Cheers
Jools
Re: Calling the coatguard by DSC? these mite help
HM Coastgurard MMSI numbers
002320001 MRSC SHETLAND
002320002 " PENTLAND
002320004 ABERDEEN
002320005 FORTH
002320006 TYNE TEES
002320007 HUMBER
002320008 YARMOUTH
002320009 THAMES
002320010 DOVER
002320011 SOLENT
002320012 PORTLAND
002320013 BRIXHAM
002320014 FALMOUTH
002320016 SWANSEA
002320017 MILFORD HAVEN
002320018 HOLYHEAD
002320019 LIVERPOOL
002320021 BELFAST
002320022 CLYDE
002320023 OBAN
002320024 STORNAWAY
002320060 JERSEY RADIO
002275200 CROSSMA JOBOURG (cap de la hague)
002275300 CORSEN (Brest area)
002050480 OOSTENDE
002500300 DUBLIN.
These are the MMSI numbers for around britain, have typed them so you can just copy and paste them.
