GrowingLad
Hi Guys,
I've got something strange going on with my engine. Volvo AQ115 (Petrol)
If I start her up from cold and leave her ticking over everything seems to be just fine...If I've been running for a while and then come back down to tickover...i.e. coming into a marina or getting ready to load her back on the trailer the engine will cut out and I notice last time it backfired once/twice. To start back up I have to turn it over for about 10 to 15 seconds and give it a bit of gas to get it going. Normally unless I haven't started it up for a few weeks it tends to start pretty quickly. If I keep the revs at around 1500 it doesn't cut out but if I bring it down to tick over it will cut out pretty quickly.
I need to double check the tickover as I'm not 100% sure the rev counter is exact but normally tickover is around 900-1000 mark. Basically I have it to the point that when I engage forward or reverse the engine has enough revs not to die....as I mentioned, from cold everything seems fine...it's when the engine has been running at higher revs for a while and then comes down to tickover it dies.
I stripped the carb down last summer and gave it a good clean out, put it back together using a new service kit.
I need to check the timing (It's got an electronic distributor) Spark plug gaps and valve gaps but have the carb at home to double check.
Now, I know what a carb does but I won't pretend that I know what exactly each part does.
I understand that the float stops any more fuel being pumped into the bowl when not needed and the accelerator pump gives it an extra bit of fuel.
I'm having a read through the manual to see what each mixture screw extra does but I've noticed some holes in the main body of the carb but it seems as though I'm "missing" a hole in the gasket. I put a thin screw driver inside the tubes and noticed that there was some **** down inside.
So, my first question (of many) is what do these holes/tubes do?
As you can see the hole that was circled is now covered by the gasket.
