Calling for help
Says a sailor who probably uses deg min and second or perhaps deg min.decimal? Deg NS/EW or +/-.
And if you want to quote your OS GB location to what precision? 6 fig is fairly routine but is actually a 10000 m2 area. More figures are possible but not every solution that lets you translate that into location on the ground will accept it. Don’t get me wrong I think W3W is mostly a triumph of marketing, but existing systems are not perfect either.
An interesting comment.
As sea I use lat and long deg min.decimal to DEG MIN.XX
On land I use OS Ref to six figures. Try putting a pencil mark on a map to an eight figure accuracy!
At sea I use sea miles, on land when driving statue miles and when walking kilometres. Sadly, I don't thing the UK is quite ready to use km on its roads.
I just think what W3W is trying to solve a problem that does not exist.
I think you just explained it’s use case! When you need to be that much more precise - it is of course possible to be precise on a map to even 10 figs if the map scale is right. But you are right for 98% of uses W3W brings no benefit - but for the tiny number of cases where someone perhaps with no training needs to get a location and pass it verbally or in printed form to another person who will type it in to a system it is quite useful. For those 2% of cases it’s horrible that it seems to still be possible to get accidental errors, is language/country dependant, and is run by a commercial company. However if it would mean EVRI actually delivered my packages or the Deliveroo driver coming to my office would find it before the food got cold I would happily put up with it!
Considering that the original question in this thread was about how to call for help from a boat on the water it has been amusing to see how much the discussion has revolved around terrestrial location finding and, in many cases, urban location finding using W3W.
For fun I have just typed our street address into W3W. The 3 word location it gave me is, literally, in the middle of the intersection of two main roads and just over a quarter of a nautical mile from our actual location. As the poster said, "...you could easily waste 10 minutes trying to find where the house actually is. And I’m not in some weird rural location." So W3W is not as useful and accurate as some might keep trying to promote.
Oh, and the solution to the "...most of the house numbers are not visible from the roadside in the dark." problem is to put your house number at the roadside next to the entrance to your property and put a light on it. Which, oddly enough, is what we have done so the emergency services don't end up stuck in an intersection looking for us in the wrong place.
Notwithstanding my criticism of w3w using plural, what you are describing isn't really the usage in the case of an emergency at sea, on a mountain or wherever, when you would simply be sharing your current location.
For navigating to a street address (or a w3w code for your front door) Google maps is vastly superior.
Discussion move on!
Thanks for that genius answer. But to know which way to head along the street I’ll need to modify all my neighbours properties too, as well as finding space to attach my new house sign, and run a cable for power. All assuming of course I’m in my own home when I need an ambulance.
No that’s operator error - which shows the weakness in street address translation. If you want your actual W3W location either manually move the pin to the right place or go outside and use your phone (may work indoors depending on signal). If you call an ambulance with that address and postcode it’s possible that their sat nav takes them to that intersection then requires the crew to use Mk1 Eyeball to get find you with road signs/streetnames/numbers.
Not always. If I go for an unscheduled swim, leaving a rather panicked Madame aboard, the best I can hope for is that she'll hit the red button and, maybe, keep me in sight.
You’re lucky, on my boat sailing with my wife the best I could hope for is she’d get the sheets etc tangled whilst she hoisted the spinnaker and bore away.
I agree with you regarding the use of W3W in remote locations where someone's device can pinpoint their location to a 9m2 square assuming the device has a stable signal to work with. But there are some who have seemed to suggest that the system is infallible and I demonstrated that it is capable of making mistakes. Do you know if the W3W app has eliminated the possibility of homonyms? If not, then there is another potential source of error.
Discussion move on!
I'm sorry, I didn't realize that you are a mod. and that I wasn't allowed to discuss.
I don't understand why your neighbours' properties need your attention. If they don't have numbers and you do, then you will proudly stand out from the crowd. Unless you are living in a bird house and your street number is 7 digits I should think there is space for your number somewhere in front. For lighting try a solar light. Some of them come with rechargeable batteries, too. It's amazing what is available in the modern shops. If you aren't home when you need an ambulance we can only hope that they don't mistake "Need, help, now" for your location and do get to you before the end of the "Golden Hour".
W3W has a search entry window which prompts for "Search for any place or 3 word address e.g. 65 Alfred Road Notting Hill, London" so I'm not sure how you get "operator error" when I followed instructions and got the duff results posted previously. Ergo, the system works but is not perfect.
I’m not a mod - you seem to be upset that a conversation about getting help at sea was discussing the utility or otherwise of a tool in urban settings.
When you arrive in my street, as with many suburban streets, you have a decision of left or right and then which side of the street to look. My house is not visible from that junctions so could have flashing lights and it will make no difference. If you’ve never encountered this issue you obviously don’t try to find addresses in suburban housing estates very often.
I’m not going to post a picture of my house but there’s plenty of houses and flats where the home owner doesn’t own the communal ground in front of their door.
Fortunately ambulance service staff are smarter than you; as it seems are W3W as need.help.now is not a valid location.
if you could robustly go from a street address to a 3m x3m location there would be no need for W3W. What you are seeing is the inaccuracy of the standard address search. You can then move the point to your actual location, or if on a device with GPS ask it for your current location. The system has its faults but this isn’t one of them!
I could go down the rabbit hole and respond but the 3 words that come to mind are "waste, of, time" .--. .-.. --- -. -.- . .-.
That might be the issue; precision.
An OS six fig ref is a 100 by 100 metre square. I don't know about you, but once I am navigating at that detail I am using the MK I eyeball.
Perhaps when EVRI or Deliveroo start delivering by drone then we will need that precision.
For me in towns I use the pub waypoint system. Up the road to the Pig and Whistle then turn left till you pass the Dog and Duck then the second road on the right.
Perhaps I’ve stoppeth one in three words on this thread as the ancient or, perhaps, modern mariner might have it.
But I know that were I to find myself suddenly incapacitated whilst on board I would rather hope that any non sea-dog crew thought to call for help via a comms device that they were familiar with and that was helpfully equipped with satellite functionality and spoke to an experienced emergency services call handler who could talk them through the issues to establish where they were and what the problem was before trying to work out how to use a vhf device that offers nothing extra in terms of connectivity beyond the faint possibility that one of the other boats in the area might contain some random not only bothering to listen but able to offer meaningful help.
Different story in the olde days when phones didn’t work offshore owing to there being no 3G (or predecessor) signal.
In your humble opinion.
But unlike perhaps most on here, I have these week assisted (slightly) in the sorting out after a land based bike accident.
The position details I was sent (by the on scene off duty medic, I believe) was by What3Words.
That is what they chose to use - and got me to the precise location (using W3W app’s link to Google maps to give directions).
W3W is a very useful addition to safety, and used particularly by the generations somewhat younger than most on YBW.
Nowhere in what I have posted did I say that the app doesn't work or that it hasn't got a use. I did point out that it has limitations based on the example given and I, as well as others, have the opinion that it is not a universal tool for location finding especially since it requires both "ends" of the communication chain to have immediate access to the app and that is not universal by any means. The "waste, of, time" was in reference to responding to the previous post with its rambles about finding a street address.
Nobody in this thread has suggested it was. It’s not perfect. The weaknesses are not the issues you have focussed on!
Neither end actually needs the app - you can use it offline (no internet) with the app or with an internet connection on the website. That is not universal - but no system is universal.
The example you gave - typing in not three words but an address and looking where it suggested the location - is not its w3w's purpose and to state the obvious, you didnt use three words at any point and therefore didn't use its actual functionality. The fact that you did what you did on the W3W app doesnt mean that it is an example of W3W in action, it is not.
However, you unwittingly have demonstrated its strength: mapping software can achieve only so much even with street addresses. But we are talking about locations that do not have a street address.
[As Ylop said] what you should have then done in your example is to move the pin to the square that most nearly represents your front door . Doing that provides you with the three words. You can provide them orally. You can provide them by a link/message (eliminating even language barriers) to anyone and that will pinpoint that precise location on mapping software, which will be able to take them to you.
Alternatively, you could have stood at your front door, waited a second whilst the GPS accuracy increases to single figure metres and then saved that (three words) and seen where it showed it on the map. It can then be provided as above to anyone and they will know precisely where that is.
Disagree.
Calling the club safety officer first means getting straight through to someone who
1. Is already afloat on a rib
2. Has good local knowledge as to where you might be based on rapid info like "in the mouth of the Roach"
3. Has almost certainly had pre event communication with the emergency services and agreed procedures etc
My suspicion is that you'd get a faster response that way.
Coming back to this…
At a regatta this week, as we are just starting our downwind leg, there was a VHF call, on the race channel, that a boat in the class ahead had an MOB “at the leeward gate”. This was responded to immediately by the PRO, who tasked a rib nearby and the MOB was recovered to by the rib and transferred back to his boat before we even sailed the 1 mile down to the leeward gate…
Would have taken a lot, lot longer than that had they hit the DSC button…
As ever, the best people to assist are the ones nearest to you!
Well said!
