smb
None of the cables from my masthead are are supported in anyway. They enter beside the sheaves and exit via holes drilled in the forward face just above the deck. The only thing holding them up is their fittings into their repective aerials/lights.
When we roll at anchor the noise from the cables is loud and annoying, an unwelcome rythmic clanging that gets on my proverbials. I have been looking in the archives for soultions but none seem ideal without taking the mast down. I have in the past tried using large cable ties fixed to a redundant topping lift with their tails intact, but this only provided slight and shortlived relief.
My next idea is to try and capture the cables at 2-3 points and secure them to the front of the mast. To do this i plan to drill pairs of holes apout 3in apart on the mast circumference, with one an inch or so higher than the other.
I will then attach a loop of cotton to the pointed end of one cable tie, probably using a hot needle to pierce a hole.
At the pointed end of another tie i will make a notch similar to that of a crochet needle.
The tie with the thread will be inserted first in such a way that it should go to the far side of the hanging cables, and then levered central.
The tie with the hook will then go fishing for the thread. Once contact is made the first tie is drawn out and made tight, and we should have a bunch of cables held against the inside of the mast.
I think 3 fixing points over a 13m mast should do it, and will take care to sand down the cut end of the ties to prevent chafe on my genoa.
My concern is really about drilling extra holes in the mast for this, and whether the cut edges need treating to prevent corrosion.
Steve
Any thoughts or suggestions are welcome
Steve
Steve
Steve
