Pagetslady
Hi what size should i use to protect 40mm2 cable I will have 120 amp alternator on my new engine.
Mike
Mike
Mike
I'd put in a 150A fuse. The 40mm2 cable will easily handle that and the alternator does not need any more.
what are you proposing to protect
The cable. So in this instance the fuse would be fitted close to the battery. Then at each reduction in cable current carrying capacity a smaller fuse is incorporated to supply that cable.
It is unlikely that a battery would deliver more that the capacity of 40mm2 cables so if they shorted out the battery would just discharge very rapidly.
Mike
