prv
Kindred Spirit has a spruce mast with an internal cable duct (I think routed out of the two halves before they were glued together). The cables emerge at hounds and masthead via rough holes chiseled through to the duct. When we got her, these were both "sealed" with a big dob of silicone, with varnish attempting to cover over it. (Naturally the varnish didn't stick well to the silicone, so water was getting under it and then continuing to track under it across the wood.)
I made a start on varnishing the mast at the weekend, and cleaned up these holes removing all the silicone, blown varnish, etc. However, I'm unsure how to re-seal them once I've finished varnishing. Two things that spring to mind are 1) re-sealing with silicone, but dig it out and reapply after each revarnishing, instead of varnishing over it or 2) make up some little copper or thin stainless "hoods" to go over the holes. 2 sounds appealing except that the cables don't really want to lead downwards (one goes around the mast, another goes upwards), and it won't be especially rainproof when the mast is lying down which it does all winter outside.
Any ideas?
Thanks,
Any ideas?
Thanks,
