chrisharris
Hi all,
Just wondering if one of the volvo experts could explain how the bypass valve is supposed to work? I understand it is designed to reduce smoke on cold start, and possibly at low loads? I know it channels inlet air either through the charge cooler or heater element, but I don't understand how it operates? Is it by sensing vacuum from the inlet manifold? I noticed that on one of my engines the banjo fitting on the end of the actuator cylinder is not attached to anything - eg there is no pipe fitted to the banjo. I assume it was either never fitted, or a previous owner removed it? I have also heard that the mechanisms can seize up - is it worth trying to get them working, will it make a significant difference to cold start smoking?
Many thanks
Chris
Many thanks
Chris
