haydude
I was wondering if anyone could give me some indications on what cancelling a french registration for a yacht involves.
Thank you in advance.
Objet: Radiation du pavillon français
No. Fr. 0000000000 (Matricule A0000)
Madame, Monsieur,
J’ai acheté récemment un bateau sous pavillon français que je souhaite faire immatriculer au Royaume-Uni.
A cet effet, je vous prie de bien vouloir trouver ci-joint l’acte original de francisation ainsi qu’un formulaire signé par le précédent propriétaire (M. John Vendor), requérant la radiation du pavillon.
Je vous remercie de me faire parvenir l’original du certificat confirmant la radiation, ainsi qu’une copie à M. Vendor au adresse suivante:
M. John Vendor
6 avenue des Bateaux
75000 Paris
Dans cette attente, je vous prie d’agréer, Madame, Monsieur, mes salutations distinguées.
THANK YOU !
One more question, is there a charge?
The previous owner has to sign a form confirming that he is no longer the owner of the boat ("Radiation du Pavillon"), and is transferring ownership to someone who will register the boat outside France. Text of cover letter below.
The boat should have an orange book the "Acte de Francisation". I recommend you take a complete colour copy of every page, because the book shows the history of ownership of the boat. It must be sent to the douaniers with the Radiation du Pavillon and it will NOT be returned to you.
The boat will be registered in a specific port. I suggest you contact the douaniers at that port and tell them you need the form for a Radiation du Pavillon, and they will be able to provide it.
I seem to recall I found it online, but 5 minutes with Mr Google and several minutes looking through the douaniers website didn't do it for me this time.
Text for cover letter:
Note that if you buy a French (or any other foreign) flagged boat, you will need to change the MMSI of the VHF and any EPIRB aboard. For most VHFs and all EPIRBs this means sending it to the factory or an authorised service dealer.
EPIRB registration is dealt with at Falmouth and no doubt a quick phone call
Agreed. When I bought my boat, I called someone at MCA or CG and they confirmed the EPIRB needs to have UK number.Not sure that is correct about the EPIRB. It needs to be registered to the new owner and the MMSI number changed. I have just done this on mine (previously registered in Greece) and it cost nearly £50 including carriage both ways.
So what happens if you ignore all this beurocracy, bring the boat back to the UK, give it a Brit name and register it here. Are the frogs going to extradite you?
Changing your EPIRB?I don't think there is a charge with the Douaniers. Maybe it depends on the size of boat. There is a charge to register on Part III of the British Register (£25 online, IIRC).
There is DEFINITELY a charge to send your radio and EPIRB to the manufacturer and have them change the MMSI. As I recall, you must first register your radios online, then you get the MMSI numbers, then you send your radio / EPIRB off for resetting.
I was lucky - I took my radio to the manufacturer (20 minutes from where I keep the boat), and the guy re-set it for free. Took him about 4 minutes. I had to pay for the EPIRB but that wasn't too bad either - an electrician dealer (200 meters from where I keep the boat) was able to contact the manufacturer get the details on how to change. I understand it is much more expensive if you have to send things by mail and based on what I've read on this forum it is more expensive in UK. Check the make of radio / EPIRB before you buy the boat, and where you can get them serviced.
Having had two, one on the US Register and another in UK, each EPIRB has a unique Hexadecimal #, all you have to do is to register it with the appropriate authority.
No sending away!!!
