Buy the right boat...... or the right engine
Buy the right boat... or the right engine
  • Buy the right boat
    Votes: 1 8.3%
  • Buy the boat with the right engine
    Votes: 11 91.7%
  • Total voters
    12
Having had both sterndrives and outboards over the years including a 20' canal boat driving it from age about 5-16 yrs old - I am certainly used to the "weave" that doesn't bother me at all.
If as I suspect I am going to keep it on a dry stack the servicing doesn't bother me as much as I think a bi or even tri annual service on the sterndrive would be ok and an annual oil change and full bi-annual service on the engine, anodes every other year that kind of thing...
I'd happily sail it over once I'd got used to the boat - but as a first-time-out trip I'd be way too twitchy.
The towcar isn't a problem I can buy something suited - the problem is going to be whether the rig is legal on a trailer - some are saying yes some are saying no - too heavy and too wide.....
I will see if the owner has ever put the trailer and boat on a weighbridge.
On transport another option could be to trail/truck the boat south to Rosslare and get the ferry to Pembroke? Its 230miles and dual carriageway / motorway most of the way. Would need some consideration on VAT upon entering the EU but if your destination is still UK then is should be okay.
Kennedy haulage have a very good reputation in Ireland. Potential to get a return trip to UK?
Haulage Contractor Boat Transport Kennedy Haulage Haulier Dublin Boat Haulage Services HIAB Crane Hire company Dublin Boat Transport Boats Haulage
Personally-I wouldn't. I wouldn't be keen on buying an older boat where at least the current owner could not demonstrate a good maintenace regime. In fact, I wouldn't go near it !
Changing oil,filters,bellows isnt going to bust the bank. If you dont change the drive oil, how are you going to know there isnt a leak- and that is when problems do potentially kick in.
You dont need VP parts for most of it-just use good quality filters,belts,oil etc. YOU also then have some confidence things are ok.
Yes, I agree with this, sterndrive fails due to water ingress are all too common, so the last thing you should be doing is extending the service interval. Going to 3 years is absolute madness. Unless I suppose he means three times a year...? don't think so.
Stern drives become especially expensive when servicing is skipped, leading to premature failure of internal parts, which are expensive and time-consuming to change. Leaving aside accident damage, there's no reason why properly serviced and maintain stern drives should not give excellent service.
Fair point - I was just hoping as it was dry stacked it would need a lot less maintenance - but as you rightly say its also about maintaining the value of the boat and I am also keen to see good service record so the next buyer will be just the same.
