Bristolfashion
So, coming into Ardglass Harbour last night - a bit late/tired/dark - and the Admiral had, unusually, been seasick. Anyway, despite having been there before and following the buoyage, we "bumped" a rock*. We were at tick over (less than 2knots) and sort of bumped across a bit - easy reverse off.
Through the water, it looks like a little anti foul has gone from the keel edge, but possibly not the white epoxy underneath.
So, when deciding what to do, on consulting the internet, the result is probably somewhere between "I do it all the time, don't worry" and "major rebuild". Most articles / advice seem to concern modern boats coming to a devastating stop at speed.
What is the collective wisdom?
The boat is a Sadler 29 bilge keel (which I would have thought was relatively tough and meant to take the odd bump when taking the ground).
Keels are cast iron
There's no evident damage inside or out.
Weirdly, the keel bolts, which appear massive, are glassed over. No sign of anything.
So, lift for an immediate check, have a look next time we lift/take the ground or forget about it.
Thanks, as even, for reading.
* The Admiral was steering and the bump happened immediately after I'd said, "don't go too close to that mark"! For marital harmony, I may not mention this again.
Keels are cast iron
