KenMcCulloch
A change from the usual starting difficulties, ours intermittently fails to stop. It's been doing this for about a year, off and on. The engine is a DV36, and occasionally when the key is turned to the stop position, the revs drop back and the engine shows signs of fuel starvation but will not stop.
The stop solenoid on the DV36 operates inside the injection pump and there is no physical override so no alternative to turning the key. We have not totally ruled out an electrical problem but there is, so far as we can tell, 12v at the solenoid when the key is turned to stop. It's more or less impossible to measure that with the engine running due to the problem of access to the terminal when the engine is vibrating.
Any insights from Bukh experts will be welcome.
