rex_seadog
On our last sail when we came to start our engine (Bukh DV20, sea water cooling) prior to dropping sails and entering harbour we found we were getting no cooling water from the exhaust and the overheating alarm sounded. Luckily we were able to moor up with minimal help from the engine. When tied up we checked the inlet strainer (OK) and replaced the apparently good and fairly new impeller and started the engine - no problem, good water flow. The next day, after a good sail, the same problem, but this time we were faced with entering the Dart against the ebb and with a head wind. We were making some progress but eventually managed to secure a tow to get us in before closing time! Next day we checked the thermostat, exhaust elbow (had massive blockage here some years ago) - all appeared OK and again from rest the engine started up with plenty of cooling water and got us up river to our permanent mooring.
Then spoke to the guys at Bukh who suggested that it was probably due to a worn pump (engine dates from 1984) so we duly removed it and have since returned it to Bukh for overhaul. They replaced various bushes and seals (excellent 3 day turnaround) but didn't find much wear to the body of the pump. We have yet to return to the boat and refit the pump but I'm still concerned that we might not have cured the problem. We haven't yet removed the T piece to check for any restriction (but poking down with a piece of wire didn't locate any apparent blockage) and once water is flowing everything is fine and we get a good healthy flow all the time i.e whether thermostat open or not, so a blockage in the system seems unlikely
It seems that when the boat is moving along under sail (even when reasonably upright) we are having the problem - from my physics of many years ago I guess this is due to the venturi effect making it harder for the pump to prime. It is only recently that this has occured so any thoughts would be welcome in case we have to investigate further.
