James_Calvert
I'd a similar problem a while back. The injector pump was the problem; it was stuck in a position that shut off the fuel supply. The yard engineer freed it off and it was ok for a season, but I ended up having it reconditioned by a local specialist.
And I think the problem was originally caused by water in the oil. In this case, it turned out to be the seals having failed in a cylinder liner. But I only found this out after a major strip down.
Do get in touch with Bukh UK at Poole, they are incredibly helpful and will talk you through anything you're unsure of, as well as providing you with parts.
