Bukh DV10 Starter motor belt
bumblefish
22 Dec 2002
Brighton
Hi, the starter belt on my DV10 has too much play and slips on the flywheel. I assume that adjusting the tension is the same as any old engine, loosen off the motor and the adjustment bolt and then move to get the correct tension? Any advice or tips?
DownWest
25 Dec 2007
S.W. France
VicS
13 Jul 2002
There are various links to this
Dynastart was fitted to early engines.
Adjust in the usual way to give 3 to 5 mm deflection of the belt by firm thumb pressure ......... See Adjustment Of V-Belt - Bukh DV10 Workshop Manual [Page 58]
rotrax
17 Dec 2010
South Oxon and Littlehampton.
You have lifted the exhaust valve by operating the decompressor I trust?
If you dont decompress the engne the dynostart belt will most certainly slip.
DownWest
25 Dec 2007
S.W. France
I have to lift the decompressor every time! Poor old engine.
Reminds me of our shaft drive borehole pump with a Lister twin. 55 mtrs of shaft down the hole...
So, you had your Wheatabix, Lifted the two decompressors and started cranking, turning the whole gubbins. Gradually got it up to speed and dropped one decompressor, praying it would fire. If not, needed to sit down and admire the scenery before having another go...
Still, as soon as it got going, it lifted 75 cu mtrs an hour. Lot of water.
bumblefish
22 Dec 2002
Brighton
