Little Dorrit
The temperature sender has two spade terminals one terminal has a yellow green wire going to the temperature light on my dash and having checked I have continuity between this (yellow green) wire and the dash light. The other terminal does not have a wire attached? The temperature light does not light up when the ignition is turned. There is 12 v on the light terminal. Have I got a faulty temperature sender or should there be an additional wire connected to the sender and if so where should this go? Is there a way to check if the sender is working?
