RichardS
N/A
If your engine is worn, a teaspoon of oil introduced into the cylinder gives a temporary increase in compression and helps starting.
Are you able to get the oil into the cylinder through the decompressor mechanism?
Richard
The engine in the very first boat I owned was a single cylinder Coventry Victor. That didn't have electric start so had to be started by hand every time. That had a cold start device that worked by injecting a small amount of oil directly into the cylinders and in fact it was pretty easy to start like thatAre you able to get the oil into the cylinder through the decompressor mechanism?
Richard
No.Are you able to get the oil into the cylinder through the decompressor mechanism?
Richard
First prime the fuel system using the priming lever on the lift pump.
Then position the starting handle so that when it is descending on the port side of the engine the engine is on a compression stripe. Doing this means my weight, aided by gravity, aided by the momentum of the flywheel, will help get the engine through the first compression stroke.
Then operate the decompressor and turn the engine at increasing speed until it's going as fast as I can do it.
Release the decompressor.
Starting is always easier if the air being drawn in is warm. A preheater (obtainable from BUKH Ltd) is worth fitting especially for winter use. Installing it is an easy DIY job. Or wrapping the air intake in rags soaked in boiling water helps.
