Slow_boat
I have a Bukh 20 with a fuel filter on the engine. There is no remote primary filter. The filter fitted at the moment is 'Crossland' make and I want to change it for an original Bukh as it hasn't been changed for three years that I've had the boat.
The filter appears to be secured by the standard single bolt through the top and that bolt holds the banjos for the fuel lines. I've tried slackening the bolt but the filter still feels firmly attached. How do I go about changing it? Is it okay to tap filter or bolt to loosen it? Does the replacement need filling with diesel before fitting?
Also, does the engine diode go in the plug by the throttle quadrant? I did it last year but that plug seems a sod to get a spanner on and the quadrant hasn't moved so could be the wrong plug. I can't remember from last year but can't see any other plug.
