cimo
looks like you're focused on the injection pump.
if any help at all -
reassemble all and apply a short sharp blow (not too many) on the case with the back of your mole grips (while working the solenoid actuator). It may just save you further disassembly.
Seen it work on tractor pumps - I am thinking your regulating rod may be stuck. if it's the control sleeve thats sticking - you may have to dismantle - but I'd try to avoid that personally.
my workshop manual states that injection timing will require adjustment after dismounting the pump.
PS - bilgediver has already mentioned the "rack" - this is what I'm referring too also when I say "regulating rod" (ref. workshop manual). the rack works the control sleeve.
