Norman_E
If you use epoxy that sets hard the energy from the transducer could shatter it over time. Interestingly, I had a chat with one of the commercial unit suppliers at LIBS, and he said that their transducers are encapsulated inside an outer casing made of glass reinforced plastic, as they think that the transducer will eventually shatter a plastic pipe fitting as used in the Jaycar kit. Time will tell, but if it does shatter I will simply use epoxy adhesive to stick the transducers to the hull.
