Zing
I own a stretch of river and would like to build a pontoon berth on one shore. The pontoon will need to rise and fall a couple of metres. Has anyone done this or knows anything about how to do it? All tips welcome.
It would be for a big heavy boat and to cope with high loads, so a proper job.
I am in the process of building a jetty for my riverfront condo.I own a stretch of river and would like to build a pontoon berth on one shore. The pontoon will need to rise and fall a couple of metres. Has anyone done this or knows anything about how to do it? All tips welcome.
It would also have room for a couple of rental berths and standards will have to be up with the best. I am the frontager, so the only permissions needed will be from the authorities.Don't know what the budget is for this but there are occasionally S/H pontoons for sale, typically on apollo duck, sometimes ebay
Boats for sale UK, boats for sale, used boat sales, Commercial Vessels For Sale 15m x 3m Concrete Pontoon - Apollo Duck
Walcon finger pontoons, suffolk - Ad 101637
FLOATING PONTOONS (TWO) | in Silverknowes, Edinburgh | Gumtree
DRB Marine Services Limited. Tel: 01436 831 231/3
Worth checking local marinas too I think, not much use to you but for example my marina in Brittany has a car park area stacked with old pontoons now replaced with shiny new ones and doubtless an appropriate increase in marina fees next year
I would recommend a T jetty where the boat is moored inline with the flow of the river , This will put less strain on the structure.
Consider having a pile at each end or the T to tale the strain off the hinged section so a smaller bank attachment will be needed.
I am using some HDPE floats my structure 50mm square tube which will be galvanised then have wood decking planks attached.
The centre leg of the T should hinge on the bank and rest on the top of the T that will rise up and down controlled by the piles, the bridge should have wheels resting on the top or the T to take up the movement.
I wonder how the piles will be put in. A pile driving machine on a barge maybe?
Thanks for the suggestion. I think this job needs something a bit more pucker. Safe for a granny and occassional high heels too.Have you thought about using a modular plastic system, such as Modular Floating Pontoon Systems - Airfloat MPS
There's one like that at Crinan, and although it is now very flexible indeed. it has been there for over thirty years now, which is pretty good going.
They're also used in Le Palais, Belle Isle, Brittany.Have you thought about using a modular plastic system, such as Modular Floating Pontoon Systems - Airfloat MPS
They get a tremendous amount of use, (and abuse!) but seem to stand up to it OK. They only problem is the lack of proper cleats to attach your lines to.
