Buckets
LadyInBed
2 Sep 2001
Me - Zumerzet Boat - Wareham
montymariner.co.uk
Seeing the thread Showering on passage using seawater drawn up by a bucket on a line. and the dangers of putting a bucket over the side while under way.
What do you have onboard?
14ltr, 9ltr, smaller, bigger. Plastic, canvas?
I have a 14 and a 9 and on the 14 I've replaced the handle with rope which also supports the bucket around under the rim, with thoughts of using it as a drouge, but never tried it!
Hard Hat on, incoming awaited.
Surely, the technique learnt decades ago as a 10 year old foredeck hand, is throw the bucket forward and pull it up at the vertical?
DO NOT let it go behind you when the flow of water takes over!
The technique is to land the bucket upside down so it fills before it gets to you.
The collapsible silicon bucket is my favourite, takes up very little space when folded. Our first one is now beginning to give up, the bucket is still OK but the handle can’t be trusted to stay fixed, but this is after about 14 years of use, so I’m not complaining.
Have bought a new one but kept the old one for scrubbing down when on our mooring.
I have two. One is a typical heavy rubber one for serious work and the other an ordinary plastic one for general use such as boat washing and storing dead mackerel. It fits inside the other and so takes up little additional space.
Found those cheap plastic builders buckets to not past the test of time and are pretty useless for boat use (unless you are in the boat yard). I have a small heavy rubber bucket which has proved brilliant, plus a strong vinyl one that stands up to being squashed etc, plus one of those two handled vinyl tubs which is great for washing clothes, ropes or fish.
In the end it comes down to what stowage is available on board. My plastic bucket is a reasonably sturdy one that I bought at a chandlers', which means that it has a ring in the middle of the handle for a rope. It is much lighter than the rubber one and would be my first choice if needed to fight a fire for that reason.
I seem to have been through a few buckets.
one I broke the bucket with a hole in it
Another the rim holding the handle broke
Another the handle rusted
Another the handle had the rings outward and would scratch the hull
The best one I have so far is a canvas one from Salty John of this parish.
So i am still searching for perfect solid one …
My favourite bucket was once a rubbish bucket that was hung on the inside of a kitchen cupboard door under the sink. It has one flat side or looks 'D' shaped from above. Makes it so much easier to use for bailing...
