Graham_Wright
…………everyone else has probably thought of already!
West Systems resin can be obtained in dispensers. I have had a few but find that after a short while they end up as a sticky mess. They are also not really applicable for the preparation of small quantities.
Having sealed a through-hull with guessed-at proportions and which never cured, I bought two syringes from the local chemists;- one 1ml, the other 5ml.
These give the recommended ratio of 5:1, are clean in use, are dedicated to either resin or hardener (so don't end up solid by cross contamination) and are easy to wipe off. The plunger is captive in the syringe so gives the required quantity by default. Best of all, they are only 65p each!
