colhel
Is there any info or tips available for giving passage ideas for cruising Brittany. ie, from here go to here, or if you prefer this sort of scenery go there, but watch out for that rock.
Are you setting out from Poole?
We love the area around Roscoff and if you can do make the trip up to Morliax.
Cumberlidge's book is what you need. Its excellent
http://www.amazon.co.uk/s/ref=nb_sb...tripbooks&field-keywords=north+brittany+pilot
Thank You Tom. Good reviews too.
I see it has waypoints, would these cover passages from port to port?
I see it has waypoints, would these cover passages from port to port?[/QUOTE
HI COLHEL,
Taking waypoints from pilot books is ok if you plot them on a chart and then figure out that the route is safe, by inspection, all other considerations taken into account.
If like I did once, you enter the waypoints correctly into a GPS, have them checked, and then find yourself in shallower water than expected, it is because there was an erratum in the printing of the pilot book.The slip of paper admitting this,may be included at the back of the publication!
So lesson learned:
1.Plot the intended trip on paper or electronic plotter,check as above.
2. Examine your purchase if new for errata.If secondhand, assume that the erratum slip is missing and take extra care in using any other waypoint other than those decided upon by oneself.
This aspect is mentioned only as it is a trap for the unwary, newer equipment allowing one to point and click in waypoints more visually without the same degree of risk as the waypoint might after insertion, be then compared with the pilot book co-ordinate to check?
