Marsupial
For the price its worth a look
http://www.ebay.co.uk/itm/NEW-4HP-O...neParts_SM&hash=item43ac8b3f25#ht_14336wt_945
There is no oil in the fuel used by 4 strokes!
A two stroke using a 25:1 premix fuel is not likely to comply with the current (EU 2006) emissions regulations for recreational use.
It'll be comparable with later, or converted earlier, Seagulls
AbsolutelyIt's usually about 4 or 5KG. The 2 strokes are about 22kg and the 4 strokes about 26Kg.
Not the huge, enormous difference that is always being suggested.
In fact in some cases (Johnson/Evinrude) where the 2 strokes are often twin cylinder, there probably isn't much difference.
careful choice of examples can always be used to mislead - as a scientist I'm surprised at you Vic,Absolutely
6hp, 2 cyl, 2 stroke Evinrude 25.4 kg
6hp, 1 cyl, 4 stroke Tohatsu 25 kg
.....and vague statistics are worse.careful choice of examples can always be used to mislead -
In most cases comparable 4-strokes are about 40% heavier than their 2-stroke exemplars -
No magic, simple arithmetic - see if you can work it out from the figures on my post. OK it's actually 38.34%.....and vague statistics are worse.
I wonder where you have magicked this 40% figure from?
I think Vic was adding bones to a contention that I raised about twins compared to singles.
A buyer is rarely going to compare like with like. They will usually buy on reputation and price.
