[3889]
Good replies, some of which go over my head, but essentially a bridle is a suitable traveler replacement for a cruiser who wants a bit less hassle when tacking single/short handed without significant performance loss.
To allay someone else's fears, the blocks are quite a long way forward of the cockpit and cannot flail around far enough to reach anyone. If you're up on the coachroof then the booms is more of a hazard...
I agree that a simple bridle arrangement is OK for a non-performance boat with a helm who isn't that interested in fine-tune. However anything that puts a fair-sized block mid-air other than close down to the deck is potentially horribly dangerous, and the illustrations shown by the OP show just that. Imagine a crash-tack from a broad reach with sheets well eased - the mid-air block could go almost anywhere. And you really don't want to be hit by one whipping around - not just sore but potentially cracked skull level.
No more dangerous than getting caught-up in the mainsheet, or having to manually sort the mainsheet out after it's got caught round the end of the traveller. The block's only on an 18-inch piece of rope, so can't fly about that much.
I would agree with jwilson on that one. & i have never had the mainsheet catch on the traveller, cannot see how it can
That's a great system, also popular on Fireballs, but depends the kicker for leach tension.On dinghies, a better arrangement to a bridle (which I define as an adjustable length strop with a block fixed mid point along it's length at the highest point) is a "split tail" mainsheet.
With a bridle, you should adjust the length depending on your chosen mast rake for that day/conditions. Although most people won't tweak mast rake on a yacht, the block won't be at the right height compared to the boom for all kicker settings. You will have to compromise between not being able to centre the main, or too much downward pull, closing the leach, in light airs.
The split tail mainsheet is essentially self adjusting. The key thing is to make the split forward of the aft block when the boom is centrelined. Here is a split tail mainsheet on my recently restored 1965 F15 (which incidentally originally had a brass horse across the stern deck) and you can see the yellow mainsheet and blue dyneema tails.
In practice, as I expected, this system was not powerful enough, so it now has an additional fall/purchase just in front on the moan jammer (which can be easily un-reeved for light days). There no reason why you couldn't replicate this system on a yacht, or even have a "German" system with the "tails" led out to either end of the track.
Mine does, every bloody time I gybe. Can you see why?
Simply not true. The only way the blocks could get anywhere near the cockpit is if they became detached from the bridle. If you consider where things will end up if they become randomly detached then all bets are off with any system.
