Gargleblaster
This may be the answer-
https://www.youtube.com/watch?v=kiv0fxFcV3I
Ditto, except I had miscalculated air height and VHF aerial was bent to about 70 degrees as we “rattled” under! Just a feeling of relief that we had not wiped out the masthead gear or worse. Could have been a very dangerous mistake.I once went under the Zeelandbruge when the electronic indicator was showing 15.6 m clearance. Mr air draft is 14.5m. I would never do it again - it was beyond scary.
Why aren't they using the norm of HAT?
Makes it seem more accessible?
When the bridge is being built I expect the clearance will be less than 18metres and certainly wont open, so that will be 6 months or so to build the central section when the clearance will be a fair bit lower. What are the chances this will be in the winter?
