Brass Rod
clyst
18 Aug 2002
Hi All
Trying to source a supply of 8 or 9mm Dia brass rod need approx 8 meters . Cant find a supplier locally (cornwall) .Anybody know of a mail order company? .Any help would be appreciated.
Terry
TrueBlue
30 Apr 2004
Sussex
Midland Chandlers of Penkridge Staffs: do brass rod in varying sizes for the narrowboat fraternity. Will supply mail order. Their brass is usually British sourced which is much better quality than Italian or Indian.
Stop what you're doing and wait my signal
snowleopard
Oxford
just a thought, but have you tried trago? along with timber mouldings there's quite a selection of metal bars, you might be lucky (ground floor, near the plumbing section)
Graham_Wright
30 Dec 2002
Gloucestershire
www.mastaclimba.com
8 metres? In one piece? You'll be lucky!
If you need smaller lengths, any non-ferrous merchant will supply.
Be aware that brass is nearly always sized in imperial. Your nearest could be 3/8" which is about 9.5mm but 5/16" is probably available also (just not in my database). I pay £1.55 per metre for 3/8". If you get stuck, I can buy it for you if you pay the carriage.
Are you sure you want brass? Not a good choice for sea water.
<hr width=100% size=1>GBW
Avocet
3 Jun 2001
Cumbria
You can get short lengths from RS (search for their website). I think you can order online.
EUXINE_Rival
5 Jan 2004
Devon
If you cant find anywhere closer try Metals SW in Newton Abbot, Devon. They suplied me with bronze rod when I needed some and are very knowledgable about grades to use in different situations. They probably have Brass in stock.
01626362026
