robmcg
Anyone know where to source some brackets to offset the coax cable from an insulated backstay? Hoping to recommission the hf radio aboard and use the existing insulated backstay.
Exactly what I do. Works very well but the cable ties need replacement periodically as they get UV damage.I use 10mm diameter plastic tubes about 75mm long. A long cable tie goes twice though it and at one end wraps around the stay, and the other end ties round the coax. The tie sort of forms a figure 8. The length of tube can be varies to set the offset, and if you don't have cable ties long enough, use two end to end.
I would think it is not actually coaxial cabler the OP is using to connect antenna coupler to back stay. You can use the centre of RG8U coax but remove the outer screen. Any screen that is earthed will add a lot of capacitance and confuse the antenna coupler. As I understand it. ol'willAnyone know where to source some brackets to offset the coax cable from an insulated backstay? Hoping to recommission the hf radio aboard and use the existing insulated backstay.
