Bowthruster Beneteau 373
westcott
16 May 2005
Hi
Can anyone help with advice on the siting of a bowthruster on an Beneteau Oceanis Clipper 373.
The ideal position would be in the bow forward of the water tank compartment but I am not sure if this would allow enough depth for the prop. I would be grateful for any advice.
Bobdehler
9 Nov 2009
Linlithgow
They seem to be fitted aft of the forward water tank.
I was looking at one ashore in Windermere a couple of weeks ago.
Can Beneteau advise?
Regards Bob
westcott
16 May 2005
Thanks for the reply Bob. However I think the boat you saw must have had the water tank moved forward, as aft of the water tank on the factory layout you have the cabin floor.
I have tried contacting the Beneteau factory but never get a response.
Thanks again
John
Monique
1 Feb 2010
Baleares
I saw an advert for an externally fitted thruster in a sailing mag... think it was "Voile et Voiliers". Away from home, so cannot scan ... oops.
Biggest problem I see is the risk of bashing them off with a resultant water way, should you ever bump your bow...
Would add some drag too but they look quite streamlined.
GL
Gelfie
15 Jul 2009
S.coast
The bowthruster I fitted to my southerly 115 is only 6 inches below waterline and works well. Go for an 8 inch tube as they work better.
Bobdehler
9 Nov 2009
Linlithgow
Thanks again
John
Attached is a picture of it John
Regards
Bob
westcott
16 May 2005
Thanks to everyone for your input and thanks for the pictures Bob. Unfortunately the photograph is of the newer Oceanis 37 and not the 373, but I appreciate the effort.
Regards
John
