Kinsale373
If the boat is a 46 footer you probaly have a 4 to 5 Kw Thruster. W+VA so you Current draw for a 4kW is 4000W/12V =333A
The only sensible way to supply this is from a Large Ah battery positioned as close to the Thruster to keep the run of very thick cables from the battery to the thruster to a min length. At over 300 Amps the heat loss and voltage drop due to resistance in thinner cables would impact on the thruster performance.
Don't dream of using the existing Starter battery. This may be just a Diesel Starting battery and not a deep cycle battery. With the current requirement of the bowthruser you always run a risk of flattening even a suitable rated deep cycle battery if you get into a tough spot and need alot of thrusting so it makes sense not to use the starter battery.
With 300A + been drawn from the battery constanty when thrusting your Alternator will need time to replace the energy drawn.
Generally the House Batterys will be toward the rear of the boat near the engines, If you want to run from these you will need to run that very heavy cable the length of the boat , it becomes very costly and increases weight.
The ususal set up is to have a large designated (Deep Cycle) Battery as close a possible to the thruster and supply this from the alternator with appropriate cables. I have a 120Ah battery running a 3 kW thruster and I can get 20 to 30 of approx 10 Sec thrusts without noticing power drop if I need it . The Manual for the thruster should give advise on the installation and how to size cables.
I have the boat 2 seasons and initially could get only 5 to 6 of 5 sec thrusts and then it began to fade. I blamed the battery and put in a new 120 Ah leasure battery. The real problem turned out to be pitting on the contacts of the reverse/ Forward relay. These take a real beating at 250to 300A. Because of the high currents all components are worked hard in these systems. Next time I'd fit proper Deep Cycle battery.
Kinsale 373
Kinsale 373
