Not sure you'll find anything online. Ring Osmotech at Hamble Point Marina for a copy of the Sleipner catalogue. I've got a copy if you want it - had a bow thruster fitted to my boat last season
Nuffink against Bow Thrusters, I just don't need one as anyone who has seen me handle a boat will tell you. If it helps someone else then all well and good.
It's the windage (side area wind strength allowed for) that deceides the power you'll need,(according to vetus stuff,at least) not really lack of weight/beam.
6.4hp & 7.3 hp ones "only" cost about £400 & £700 more,respectively larger batteries needed.
from reading a lot, & playing about (a bit) I see them as there to compensate for the wind blowing the bow off- hence mention of area above water + wind strength you want to deal with- in zero wind, you'd hardly want one, would you?. So not convinced that weight plays much part, except that light'ish planing boats do blow off much more easily-so could argue bigger one needed for your type of boat,compared to lardy steel cruiser.
actual experience limited to dutch steel river cruisers 11m ish, 8 hp is nice for that, tho' some have larger.(seen up to 15hp hydraulic on that size boat)
I'd think that you can buy too large, hence (expensive) speed controllers available, to calm it down a bit & avoid jerky on/off motion.
batteries?: vetus (again!) suggest 12V 108AH for 4hp, then 200AH & 220AH for 6.4 & 7.3 models...also a few quid extra re.larger cables.
(1/2 the AH for 24V)
