The last owner of our new boat [Mirror Offshore] fitted a two burner gas cooker in a swing down box that fastens up on the cockpit bulkhead inside the boat. The gas supply, also inside the boat on the floor under the cockpit sole, is via reinforced rubber tube from the gas bottles screw in valve, all conections are secured by jubilee type clips.
Now the problem is, all that I have read says that this is an unsafe set up, yet all my friends [boat owning] and my wife, think that I am being overly cautious. As a compromise what about only using the thing by having the bottle separate and only conecting it when its out in the cockpit in the fresh air. But then what about any unburnt gas just prior to ingition, wont that seep down into the lower bilge and become a potetial danger. Whilst I may be able to vent the cookers tray to the outside, there is nowhere I can put a outside vented box for the gas bottle.
OK then lads and lassies what do I do ? Carry on as is , on the basis the risks are overstated ? Ditch the lot and get an alcahol/Meths cooker ? Shrink a 10lb gas cylinder down to match box size and keep in the cockpit ???? Advice and ideas Perleeze !! Oh and before the week end too...
