I have a Ford Leyman Super 90HP engine with a Borg-Warner Velvet Drive Transmission. Recently I have had to top up the transmission with about a quarter of a pint of ATF every 30 hours of running. There are no external leaks visible or any ATF in the bilges. I have tested the gearbox oil cooler to 7 bars and am confident that its OK. There is no drain plug in the bellhousing so I cannot see if the escaping oil is gradually filling it up. The gearbox works perfectly. Has anyone had a similar problem with this gearbox and can give an indication as to what I can do to trace the leak before I take the drastic step of taking the gearbox out.
regards,
Colin
regards,
Colin
