steveeasy
Hi.
Perking 4\236 m lowlife has a borg warner 2.1 reduction hydrolic gearbox is leaking hydrogen oil from front bell housing area. Trying to remove gearbox to get repaired. Boat in water .plan was to disconnect shaft coupling.slid shaft back then remove gearbox.
As usual failed on first hurdle. Tried to undo 4 coupling bolts and studs all came loose.so need to cut studs. However when removed will I be able to change studs from coupling easy. Shaft dia is 50mm.
Any advice appreciated on possible leak and coupling design.
Steveeasy
Steveeasy
