youen
I have cleaned my teak deck with Starbright teak cleaner some parts are very clean but on others it stays black stripes .If I use Boracol will these black stains disappear.Thanks
I used Polycell 3 in one mould remover to remove stubborn stains and green mould on my deck and it was amazing. All the green in the little crevices disappeared almost right away. I've treated it with two coats and will report on how it's done by the end of the season.
After applying boracol how will be the teak,can the grp be spoilt if some boracol is dropped on it.Thanks
Someone here did say (as far as I recall) that terrestrial mould/fungus killers are very toxic to marine life. If you've got a conscience, don't use them afloat.
The active ingredients in the Polycell products are the same as those in Boracol, just more dilute in the Polycell product.
The only possible Polycell product I can find is its Mould Killer. The safety instructions do not make encouraging reading.
Yes, that's the stuff, and Boracol has exactly the same ingredients, although more concentrated.
Boracol: Boracol 10RH, 10% disodium octaborate and 2% active Alkyldimenthylbenzyl Ammonium Chloride blended with water and special carriers (water soluble).
Polycell: BENZALKONIUM CHLORIDE<2.5 and DISODIUM OCTABORATE 2.5-10
If some boracol is poured on the grp can the grp be damaged
