smithy
I am changing over to slab reefing from the old roller boom system. I have sliding cheek blocks on the side of the boom but no sure what kind of cleats to use, jamming or horn? Any suggestions? 29ft boat
Have something of the same problem, but find that if you hoick the boom up on the topping lift it ain't too hard.I had slab reefing with jamb cleats on the boom on my 26 ft TS.
Actually pulling down a reef in a strong wind and with a good sea running and the boom shaking around was a considerable challenge. Worse though was that with no additional purchase i could not tension the foot enough to flatten the sail. If your reefed sail ends up baggier than your flattened full sail, you can be worse off in terms of capsizing forces.
Running the reefing lines through a clutch to a winch in the cockpit has meant that all the drama was taken out of the reefing exercise and i can really get some tension on the foot of the sail. Getting the reefed sail properly flattened has made a big difference to sailing speed and also comfort.
