alanporter
My 1976 Westerly Renown does not have the through-hulls bonded to any common earth point. Except, that is, for the engine cooling water intake which is bonded to the engine. My shore power system earth wire,(120 volt in Canada), is not connected to the DC common earth point, as is recommended by some people. I always check that the shore earth connection is good before using any 120 volt mains appliances.
My philosophy for all this is that the risk of galvanic corrosion will be reduced. Am I correct ? or should I be doing something else ? Expert advice will be much appreciated.
<hr width=100% size=1>Alan Porter
