CPD
I have a few small holes (in gelcoat/fibgreglass) after renewing some cockpit latches, which now need filling up. Whats the best thing to use ?
When still in UK i used to use Plastic padding gelcoat filler which came in a tube with a small tube of hardener and was white. plastic Padding isn't available here in the USA and the West product is only sold in big and expensive cans so I just used a small tube of 3Ms 2200 adhesive sealant in white that worked well to fill holes left when we fitted a new heads.
+1 for both of these with slight differences...
stainless bolts with washers bedded in butyl tape - less messy than sikaflex/sealant gunk..
gelcoat filler you can get from ebay http://www.ebay.co.uk/itm/Gelcoat-F...e-Junior-/331190555899?_trksid=p2054897.l5663
..another aquaintance swears by Milliput for above the surface hole fixes.... not tried that yet
How about putting some stainless bolts with washers bedded in Sikaflex& just fastening. Will not look out of place & holes can be re used later.
Got a box today. Thanks for the help chaps !+1 for Plastic Padding Gelcoat filler.
