The Full keyboard Tonewheel Hammonds were the C3, RT3, A100, B3. They also did reduced keyboard models M100 and L100. This smaller "spinnet" model was also split and sold in a white paint finish known as the M102. The larger full keyboard models were also occasionally split to assist in transporting although the B3 was a top half on legs and remains the most desirable of the Hammonds. Hammond also produced a model called the X5 (where perhaps the C5 error is creeping into other posts) which was an organ supposidly designed for bands on the road but never really cought on in a big way although the sound was quite good. Hammond stopped doing the tonewheel thing with valves and started making a range of organs with transistorised circuits, ditching the mechanical tonewheel generator. Big mistake, these transistor organs are faily common and practically worthless.
The Sound of the Hammond is greatly enhanced by using a Leslie speaker. This is a speaker cabinet which looks like a large Oak or Mahogany box (some Cherry wood were also made, and contains two speakers, one a large bass speaker in the bottom of the cabinet points down and the sound escapes through a rotating drum and the other speaker points upwards and escapes through a set of rotating horns. The organist can select slow or fast rotation and the effect is staggering.
If the organ you have Adrian is a B3 then it is worth a few bob and I would love to buy it if you cared to part with it. If it is a C3 then its worth around £1200 with Leslie. A100's and RT3's are not quite so desirable asthe A100 has speakers in the body of the organ (so its very heavy) and the RT3 is wider and again heavier.
M100 and L100 are only worth around £100 and Transistorised versions J125, T500 etc etc etc are not worth a bean.
Cheers all, Not boating is it but then I don't have a boat!
Been considering V52's but I prefer the T48. Mind you with the 800 hp set up It goes over 40 knots. Suprising how the T48 only produces another 2 knots (35) with the 74p's bearing in mind its another 100 HP over the 74L or Cats.
My search is rather drifting aimlessly at the moment. This sounds terrible considering the budget we've got but I just cant get all that excited about any of the boats we've looked at including the T48. SWMBO thinks we should be buying a flybridge boat so thats complicating the situation. Might just wait for LBS and see if any juicy p/exs come up. What about you?
i had a t48. Had it in the uk for a while, though (like most boats i suppose) more fun in the med. The extra 2 knots for bigger engines is due to the fact that the 33/34 knots was a big lie, whereas the 35 is less of a lie.
In the UK, t48 is a load of zipping and unzipping things. Yes, flybridge or command bridge better if uk-only boating is planned
Agree v52 is more money, and possibly seems a tougher design. For med, v52 has too-small swim platform, irelevant in uk. Inside, weird cornish types have designed high-gloss worksurfaces and galley, great for buying a pastie and not cooking anything at all. Fairly bland interior, not very special-feeling ,that fairline seems better at....
Whats your opinion on bathing platforms in the Med, tcm? Is it better to have a large platform with dinghy stored on it or a smaller one with dinghy in davits?
<Whats your opinion on bathing platforms in the Med, tcm? Is it better to have a large platform with dinghy stored on it or a smaller one with dinghy in davits?>
this is a few questions in one!
conditions (in no partic order)
1 At sea , you need to be able to stop the boat and fish things out from the stern and have a quick swim without the dinghy being in the way.
2. In harbour, you need to be able to get on and off, without the dinghy in the way
3 In harbour, you need to be able to attach crossed lines, without the dinghy being in the way.
4. You need to be able to get the dinghy in/out reaonably reasily and reliably.
5. in harbour, with dinghy on, the back of the boat must not look like a pile of crap, cos you see it all the time with stern mooring.
So your options are best of a bad job: either on davits or on the stern, whichecver is easiest. Saw jfm's use thepassarelle to hoick onto swimplatform. BUT they wd have to launch the dinghy before larking about AND not much larking cos the chocks are still there. But more positive location (i think) with chocks, it seemed to me. Probably limited size of boat/engine if on davits, or for given boat, more limited than on chocks. But the crossed lines are often needed imho, and chocks can bog this up.
However, both options violate a few of the rules above. A flybridge mounted dinghy might be okay, never tried it tho. The leopard, v52 and t48 don't violate any of the rules, as far as I can see. Best is the targa 48 as the second option (when the lectric fail) is to haul manually, not possioble with bigger jetboats.
Best imho is the pershing, or larger sailyboats, with dinghy coming out of the foredeck. Or stay at anchor and get the dinghy out for a while...
Stone Me has been playing today in Chatham, in and out of its pontoon, looks like the new owner and wife are having lessons, as usual the wife is doing all the easy bits like jumping off the boat with the lines between her teeth.
Yes, need to launch dinghy to lark about, but it's very quick to launch, quicker than garage set ups. With dinghy in water, chocks can be removed easily, ....and erm stowed somewhere that fits big things.
Big prob with chocks is possible inability to have crossed lines in stern-to mooring set ups. We simply cant do it on ours, as the crossed lines would snag on the dinghy. This worries me in strong winds, we need to sort out some way of having these mooring lines, but haven't figured a way to do it yet......
No way to get dinghy up on top on the flybridge? Maybe using some form of crane type contraption adapted to fit the pasarelle? Or maybe a proper crane on the flybridge and lift it up out of the way?
That way you could get your crossed lines on. Or maybe just lift it up a bit and slide sideways out of the way? Or just drop it in the water, though presumably then you get barnacles growing on the dinghy I suppose,
I'm sure between us all here we could come up with a suitable (patent pending) design.
rear pop-up cleats, mounted well back on the swim platform can do this. I have these, quite good.
But nonetheless, still can loo ka mess with dinghy etc etc on the swim platform. Each little swim stop stop requires bogging around with dinghy, and yer need a biggish flybridge to start plonking cranes and dinghies up there.
t48 quite quick to launch/retrieve dinghy, praps as quick as jfm's chocks, or nearly. Pus loads prettier arse end. Why the hell am i talking to coliholic about this?
I got all cross lines to my brain whilst typing summink bout "good-looking arse ends". Then typed the next thing that came into my head. Then before, i could stop, i pressed the continue button, my mind swirling in a confusion of metaphors.
